In Path of Exile: Keepers of the Flame, players can now instantly refund their entire Passive Tree and Atlas Passive Tree, making one of the game's biggest quality-of-life changes yet. This new feature completely changes how players approach experimentation—it removes the fear of getting locked into a bad build or wasting currency when trying something new. You can rework your build or adjust your Atlas direction on the spot, encouraging creativity and faster progression without the usual grind of respecing point by point PoE 1 Currency.
The process is simple. Through the passive tree or Atlas interface, players can choose to refund all points at once, returning them to their pool to be reassigned immediately. The feature is designed to be accessible but still balanced within the game's economy. It likely comes with a reasonable in-game cost—something that ensures you think about each reset without making it punishing. This strikes a balance between flexibility and intention, keeping experimentation rewarding but not trivial.
The dual refund system affects two major parts of the game: your core character build and your endgame mapping strategy. Being able to reset the Passive Tree opens the door to rapid testing of new keystones, cluster jewels, and damage setups after patches or balance changes. On the Atlas side, it lets players reshape their endgame focus—shifting between map types, league mechanics, or farming routes as easily as changing gear. Together, these tools make it far easier to stay adaptable as new content arrives or metas evolve.
For everyday players, the change means far less hesitation when trying new builds. You can test fresh skill setups, experiment with defenses or auras, or even rebuild your entire playstyle without weeks of farming regret or regret orbs. Newer players benefit even more, since early mistakes in planning won't slow them down as harshly. For veterans, it's a direct boost to efficiency—less time spent redoing points and more time spent fine-tuning high-end configurations or testing different league mechanics.
That said, there will likely be limits in place. Some features might have cooldowns or usage restrictions to prevent constant swapping, and certain passives—like Ascendancies—may still need to be reset through their own process. These constraints help preserve the feeling of progression while keeping the system from being abused. In practice, most players will probably use full refunds strategically, mapping out new builds in advance and switching once they're ready to compare results.
To get the most out of the feature, it helps to plan ahead. Before using a full refund, define your goal—whether it's boosting a specific damage type, improving survivability, or testing a new farming route. On the Atlas side, think about which endgame goals or league mechanics you want to emphasize and how the new layout supports that. Having a few reference builds or notes makes the transition smoother and helps you get back to farming faster.
Keepers of the Flame looks set to reshape how players approach build design in Path of Exile. The ability to instantly reset and reallocate passives makes experimentation faster, more flexible, and far less punishing. It encourages creative builds, quicker adaptation to balance patches, and a livelier meta where players can test ideas on the fly Divine poe 1. For anyone who enjoys theorycrafting or optimizing their endgame setup, this feature promises a huge boost in freedom and flow—making the game's deep build system more approachable and exciting than ever.
U4GM PoE: Adds Instantly Refund Passive and Atlas Passive Tree
Přejít na
- Fotovoltaika
- ↳ FAQ a rady pro začátečníky
- ↳ Elektrárny uživatelů
- ↳ Hybrid Rosice
- ↳ Jančiho podtatranske solarka
- ↳ marsalovy FVE
- ↳ Dumiho ostrůvek
- ↳ FVE by ReGe
- ↳ redcrownův poloostrov
- ↳ Rosovice4
- ↳ Ompitál
- ↳ FVE 6600 Wp - Sobrance
- ↳ Antoniho, malá ale rastúca ekonomická FVE, Liptov
- ↳ Plazivcova FVE
- ↳ Ostrovna trucovna ala El Salvadore
- ↳ Dům Zítřka - energetická soběstačnost
- ↳ Baalikova FVE
- ↳ Kotyho hybridní FVE Solax
- ↳ OndraS FVE svépomocí
- ↳ Ostrov Moravka Solax
- ↳ Aktuality ze světa FVE
- ↳ Elektroporadna
- ↳ Baterie
- ↳ Měniče
- ↳ Axpert
- ↳ Meanwell
- ↳ Studer
- ↳ Victron
- ↳ Ostatní
- ↳ Regulátory
- ↳ EPever / EPsolar
- ↳ PCM
- ↳ Studer
- ↳ Victron
- ↳ PWM regulátory
- ↳ Ostatní
- ↳ Make Sky Blue
- ↳ Panely
- ↳ Montážní poradna
- ↳ Victron komunita
- Elektrotechnika
- ↳ Přestavby na Lion/LiFe akumulátory
- ↳ Aku zařízení, nářadí, hračky
- ↳ Nářadí
- ↳ Sekačky
- ↳ Automatizace, řízení
- ↳ Tecomat Foxtrot
- ↳ Home Assistant
- ↳ Homemade elektronika
- ↳ Domácí elektrospotřebiče
- Elektromobilita
- ↳ Elektromobilita obecně
- ↳ Elektromobily
- ↳ Elektrokola
- ↳ Elektromoto
- ↳ Baterie pro elektromobilitu
- Větrná energie
- ↳ Využití větrných turbín
- Komerční zóna
- ↳ mivvy ENERGY - rady, postupy, návody
- ↳ Komerční nabídky
- Bazar
- ↳ Prodám
- ↳ Baterie
- ↳ Fotovoltaické panely
- ↳ Měniče
- ↳ Regulátory
- ↳ Ostatní
- ↳ Koupím
- ↳ Baterie
- ↳ Měniče
- ↳ Regulátory
- ↳ Ostatní
- ↳ Vyměním
- ↳ Daruji
- ↳ Stálý prodej
- Srazy
- ↳ Celorepublikové
- ↳ Regionální
- Ostatní
- ↳ Lampárna
- ↳ Kutilové, zahrádkáři, chovatelé, kuchaři
- ↳ Žumpa
- Provoz fóra
- ↳ Aktuality ohledně fóra
- ↳ Návrhy a připomínky
