homeassistant - goodwe a mereni po fazich
mate nekdo hotovy mereni ve fazich v home assistantu, abych nevymyslel kolo?
tj. na bazi sensors: Meter Active Power L1, L2, L3?
muzete se podelit o reseni?
ideu mam takovou, ze vytvorim 6 helperu pro scitani...Nebo nejaky lepsi zpusob?
Re: homeassistant - goodwe a mereni po fazich
A zajímá tě to opravdu po fázích, nebo ti jde jen o oddělení odběr z DS vs. dodávka do DS?
edit: použil bych to takto
Kód: Vybrat vše
- platform: template
sensors:
power_buy:
friendly_name: "Power Buy"
device_class: power
unit_of_measurement: 'W'
value_template: >-
{% set l1 = states('sensor.meter_active_power_l1')|float(default = 0) %}
{% set l2 = states('sensor.meter_active_power_l2')|float(default = 0) %}
{% set l3 = states('sensor.meter_active_power_l3')|float(default = 0) %}
{{ '%i'|format( iif(l1 < 0, 0, l1) + iif(l2 < 0, 0, l2) + iif(l3 < 0, 0, l3) ) }}
power_sell:
friendly_name: "Power Sell"
device_class: power
value_template: >-
{{ '%i'|format( -1 * (iif(l1 > 0, 0, l1) + iif(l2 > 0, 0, l2) + iif(l3 > 0, 0, l3)) ) }}
to scitani po fazich se mi hodi do "custom:power-flow-card-plus"
ale spatne jsem napsal dotaz.
jeste jsem chtel sumu za den z techto hodnot .. tj. v kWh.. (import/export kWh za den)
edit
sumu jsem tedy vytvoiril pres ty helpery
total_buy
sensor.total_buy
Integration - Riemann sum integral sensor
total_sell
sensor.total_sell
edit
total_buy
sensor.total_buy
total_sell
sensor.total_sell
Kód: Vybrat vše
# Sensor for Riemann sum of buy energy consumption (W -> Wh)
- platform: integration
source: sensor.power_buy
unit_prefix: k
round: 1
method: left
# Sensor for Riemann sum of sell energy consumption (W -> Wh)
source: sensor.power_sell
unit_prefix: k
round: 1
method: left
energy_buy_daily:
source: sensor.total_energy_buy
cycle: daily
energy_buy_monthly:
cycle: monthly
energy_buy_yearly:
cycle: yearly
energy_sell_daily:
source: sensor.total_energy_sell
cycle: daily
energy_sell_monthly:
cycle: monthly
energy_sell_yearly:
cycle: yearly
tak nevim, delam neco spatne.....
co tam mam blbe?
Invalid config for [sensor.template]: [source] is an invalid option for [sensor.template]. Check: sensor.template->sensors->energy_buy_daily->source. (See ?, line ?).
/config/configuration.yaml
co tam mam blbe?
Kód: Vybrat vše
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
#tts:
# - platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration entry
sensor:
unit_prefix: k
round: 1
method: left
unit_prefix: k
round: 1
method: left
sensors:
power_buy:
device_class: power
value_template: >-
power_sell:
device_class: power
value_template: >-
energy_buy_daily:
cycle: daily
energy_buy_monthly:
cycle: monthly
energy_buy_yearly:
cycle: yearly
energy_sell_daily:
cycle: daily
cycle: monthly
energy_sell_yearly:
cycle: yearly
Nejmenují se ty senzory u tebe jinak?
Tohle ti funguje?
Kód: Vybrat vše
Jestli to dobře chápu tak tento součet by měl ukazovat cca skutečný odběr nebo výkup tzn. být blíže k hodnotám elektroměru než sensor total energy import/export přímo ze střídače kvůli "problému" s asymetrií? Je to tak prosím?
Ano, je to tak.
omlouvám se za začátečnický dotaz, kam a jak mám kód vložit ? Návod pro blba prosím. Zkoušel jsem ho v šablonách a evidentně funguje (sell i buy).
A aby toho nebylo málo, jaké senzory mám zvolit pro energetický panel (soláry, baterie i rozvodná síť) když chci vidět aktuální stav FVE? Pořád zkouším různé senzory, ale stále mi to ukazuje nesmysly. Rád bych se dostal na lepší a čerstvější data, než mi poskytuje SEMS portál.
Goodwe 10KN-ET Plus+; Sunergy 450, Pylontech Force H2; Home assistant Green
Chvalme pána, teda danidani, díky moc, už to ukazuje dobře.
Zdravim, snažím se přidat do HA měření po fázích. Kod se mi tam načte, ale když udělám kontrolu
tak mi to píše tyto chyby. nevíte co s tím ?
Varování nastavení
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 61: required key 'value_template' not provided
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 62: 'source' is an invalid option for 'sensor.template', check: sensors->energy_buy_daily->source
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 63: 'cycle' is an invalid option for 'sensor.template', check: sensors->energy_buy_daily->cycle
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 64: required key 'value_template' not provided
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 65: 'source' is an invalid option for 'sensor.template', check: sensors->energy_buy_monthly->source
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 66: 'cycle' is an invalid option for 'sensor.template', check: sensors->energy_buy_monthly->cycle
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 67: required key 'value_template' not provided
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 68: 'source' is an invalid option for 'sensor.template', check: sensors->energy_buy_yearly->source
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 69: 'cycle' is an invalid option for 'sensor.template', check: sensors->energy_buy_yearly->cycle
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 70: required key 'value_template' not provided
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 71: 'source' is an invalid option for 'sensor.template', check: sensors->energy_sell_daily->source
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 72: 'cycle' is an invalid option for 'sensor.template', check: sensors->energy_sell_daily->cycle
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 73: required key 'value_template' not provided
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 74: 'source' is an invalid option for 'sensor.template', check: sensors->energy_sell_monthly->source
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 75: 'cycle' is an invalid option for 'sensor.template', check: sensors->energy_sell_monthly->cycle
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 76: required key 'value_template' not provided
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 77: 'source' is an invalid option for 'sensor.template', check: sensors->energy_sell_yearly->source
Invalid config for 'template' from integration 'sensor' at configuration.yaml, line 78: 'cycle' is an invalid option for 'sensor.template', check: sensors->energy_sell_yearly->cycle
Varování nastavení
všechno jsem zprovoznil dle návodu, ale mám malý problém.
Prodej a nákup je prohozený v Sunsynk powerflowcard. Energy karta z HA ukazuje správně (ale do té jsem nijak nezasahoval, počítá dle nastavení z integrace Goodwe)
Screen z dneška.
Nevím jestli to je nastavením Sunsynk, ale nic jsem tam nenašel, spíš mi to přijde, že je to fakt prohozené tady v tom vzorci s těmi fázemi.
Mohl by na to někdo zkušený prosím hodit oko?
předem moc děkuji
Screen z dneška.
předem moc děkuji
